This is going to sound like a silly question but here goes. I recently downloaded and avi file and wanted to burnit onto a vcd. When I opened up the file though it was upside down and inverted. Is this a problem on my part (ie missing codec or something like that) or did someone actually author and avi file upside down and inverted. I beleve I have a couple like that from the same author. I just find it rather odd that someone would do that after they put there name as a watermark in the corner so people can read it but put it backwards.
Has anyone else heard of this or is it just me?
Thanks for any help,
Jennifer
i had the same prob i geuss, i burnt a movie onto vcd (after i cut it up) in avi format and it played upside down on my dvd player but fine on the comp
If you loaded the NIMO Codec pack and included the BICUBIC RESIZER FILTER then the picture will do that. I also think that it may fix that upside down file if the file it's self was faulty. ( Not sure though)
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Colors Reversed? Inverted?
By Abbadon21 in forum RestorationReplies: 3Last Post: 17th Dec 2011, 08:00 -
Inverted Video
By PaPaDeath in forum Video ConversionReplies: 4Last Post: 20th Nov 2008, 21:48 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 07:13 -
Build 2.5.3200 - Successful AVI-conversion - Upside down image..
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 4th Oct 2007, 16:58 -
My Nerovision files play upside Dpwn
By garry55 in forum Software PlayingReplies: 2Last Post: 3rd Jun 2007, 18:03
