How do I check for bad frames? I used VDub and did it that way. But when it got done checking it didn't tell me which ones are bad.
Stoked
You should use VirtualDub MP3 as it creates a log file which lists which frames are bad.
Here's a guide for taking out by frames with VirtualDub MP3 Freeze:
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
I have the MP3 freeze version but I don't know where to find the Log.
Stoked -
It's usually in the "COriginally Posted by St0ked56
rive" directory of your computer.
:P
The log displays which frames are bad in your source.
:P
I know where its supposed to be, but its not there. Ive scanned the movie at least 6 or 7 times and I still get the same results(Nothing, all it says it 3 bad frames at the bottom of VDub). I can't find the logs anywhere in the CPU I have Version 1.5.0. Any ideas?
Stoked
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
