I've heard that you cannot have both Nero and Easy CD Creator 5 Platinum on the same computer without conflicts. Does anyone know if this is true and, what specifically are the conflict(s)?
Thanks,
The conflict that i had when i had both installed is that when i loaded a cd into my drive the computer would totaly crash when it read it with an error
fatal exeption in vxdhelp.vxd. this still occurs when one of the programs is uninstalled but is easily fixed by disabling the offending file or files in windows\system\iosubsys -
I found that you cannot have the DLA aspect of both software packages running at the same time. I did have both installed and each worked fine as long as I didn't use the DLA. I used them more for the DVD writing. I did switch over to RecordNow MAX (for the DVD writing)
Nero 11 Platinum
By tarzan54 in forum Newbie / General discussionsReplies: 10Last Post: 22nd Feb 2012, 21:01 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 01:30 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
DVDFab Platinum
By bigdogdadog in forum Newbie / General discussionsReplies: 9Last Post: 3rd Nov 2007, 16:06 -
Nero Recode 2 vs DVDFab Platinum
By eon_designs in forum DVD RippingReplies: 8Last Post: 14th May 2007, 11:58
