if you have been having problems with your dvd showing only play instead of the time - here is a fix (thanks to Sonic Foundry/Creative Cow)
http://www.sonicfoundry.com/forums/ShowMessage.asp?MessageID=154820&Replies=9&Page=3- First, download ifoedit. This is a program that lets you manipulate the IFO files for a DVD.
- Backup VIDEO_TS.IFO and VIDEO_TS.BUP from your VIDEO_TS directory
- Run Ifoedit and open up VIDEO_TS.IFO (open button at bottom left).
- Click on "VMG_PTT_SRPT" in the top frame.
- In the bottom frame you should see a line like this:
[00000008] Title_1: Title playback type 84
- Dbl-click on that row and change the 84 to 0.
- Do this for every other program Title you want to be fixed.
- Click save and make sure it is VIDEO_TS.IFO.
- Click Yes when asked if you want to save as BUP also. (The IFO file is very important for the DVD, so the same file is duplicated. The .IFO and .BUP file are exactly the same.)
Results 1 to 1 of 1
How to fix long VOB seek times
By aliasx51 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Apr 2008, 12:02
