Hi,
got some mpgs saved with a PVR digital satellite receiver. Demultiplexed and patched them with DVDPatcher 1.05 (they are 480x576 PAL, patched as 352x576).
Trying now to import them in SpruceUp, but at half process (the position changes on each file) I get "Parsing error". Ok, there are some bad frames. How the hell do I clean these files ?? And in general, how do you clean corrupted Mpeg files (Mpeg1 and 2)...??
Tried M-1Edit, the transcode function. No way.
Tried VCDGear, the fix mpeg errors function. No way.
Tried Mpeg Corrector. As above.
There should be a sw out there that recognizes bad frames and overwrite them with the previous one or the next one....or do I have to write it ??
Thanks.
PS: Using another Authoring sw (I have here DVDMaestro and DVD Workshop) could be a workaround ?? Do these sw perform a different check on the imported files ??
After a re-encoding video job I got a parsing error in DVDMaestro as well.
Solution: "re-encode the video again."
You could also try saving the video into another format and then back to the original format, it's worth the try.
MrSnakeSony DRU-500A v1.0d
Toshiba SD-M1302 v1006
Philips DVDR885P v1.7/8
Vegas movie studio 10 "out of memory errors"
By magillagorilla in forum EditingReplies: 19Last Post: 25th Oct 2011, 10:58 -
I don't understand these errors saying "wrong version".
By saltyjd1 in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Mar 2011, 14:52 -
SOLVED!! - AutoMKV stuck on "parsing profiles"... (not respondin
By TooLFooL in forum DVD RippingReplies: 7Last Post: 3rd May 2008, 08:35 -
Out of Memory Errors Re-Coding "WAR" for Backup
By Newminds in forum DVD RippingReplies: 1Last Post: 6th Jan 2008, 12:00 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 17:32
