I have succesfully managed to convert my XViD onto VCD. However i have spent the last full 3 days trying to convert to SVCD and I'm getting mad with that.
The result is a major out of syn for the audio even though the audio itself is the same playing time as the movie......
Can't understand what's wrong.
Can somebody help ? Where can I find a comprehensive guide to convert XViD to SVCD ?
Cheers
I always use Vdub to save out the Xvid into another avi. Choose full processing mode on the audio, choose full processing on video stream use 4.12 as your compressor (ie recompress useing different codec). Save the lot out as a new avi, this might take 1-2 hrs and file will double in size.
Then use this in tmpg to convert to svcd, I then use VCDeasy to create cue and bin file from the mpeg and insert chapters. Then use Nero to burn.
you may get better results using dvd2svcd and CCE if you have a bought version!!
Good Luck Tom -
Have you got some sort of guide cause I can't get it to work...
I might be doing something wrong.
Cheers
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 14:02 -
XviD avi out of sync
By Silenceville in forum Video ConversionReplies: 17Last Post: 17th Feb 2009, 10:12 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38 -
How do I sync xvid and audio?
By BiggerJim in forum AudioReplies: 0Last Post: 22nd Feb 2008, 19:35 -
vob/ifo to xvid audio sync problems.
By spiked in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 17:19
