  1. Member curryman's Avatar
    Jan 2003
    could someone please tell me how to burn a karaoke cdg compliant disc, i have the wave files and the cdg files in zip folders but was wondering if there was a certain way to burn them??
    if anyone knows, they would make a little girl very happy
    Apr 2003
    Wales, UK
    I have come across the same problem and found out thatyou have to have a cdg compatible writer to be able to write cdg format. I am purchasing a cheap one off ebay,check out plextor and yamaha they seem to be the best. Try and get hold of a program called cdg+toolz this then converts them to a bin file which you can them burn to cd with cdrwin on your (cdg compatible drive ) If you like i will keep you posted of my progress e-mail tdjones32@hotmail.com.
