i converted two divx movies to dvd format at a lower bitrate. i want to fit these on a dvdr. i'v succesfully done so before, but these two movies are in pal format. i switched everything over in ulead for pal and converted the files with tmpge. the resulting files are 2 gigs each,but when i put them in ulead dvd movie factory they come up as 3.8 gigs each. how do i correct this? ntsc format stays the same size in ulead.![]()
Guest
even though you converted @ a lower bitrate, DMF will always for th efile back to standard bitrate. found this out the hard way trying to make a xvcd
used kvcd 1 dics template got the file to under 700mbs, DMF blew it back up....
bloo
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20 -
Ulead Movie Factory Issue / Mpeg files
By DVDdummy in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2007, 23:57
