  1. Here are the release notes:
    Build 15584 (Version 1.5.0): [February 16, 2003]
    [features added]
    * Can add a single job to the batch list with syntax:
    /p[input_file],[output_file]
    * Filters are now loaded and unloaded on the fly to
    circumvent TLS (thread local storage) selector limits.
    * Cropping bounds can now be dragged via the mouse.
    * Improved, friendlier crash diagnostics.
    * Basic audio filter support (no plugin support yet,
    though). The pitch shifter sucks.
    * Increased accuracy of audio/video timing by switching
    from microsecond to rational calculations.
    * Changed font on dialogs to enable ClearType on XP.
    [features removed]
    * Deleted outdated 3x3 average filter -- it has been
    superceded by "blur."
    [bug fixes]
    * New MPEG audio core (Priss) -- fixes decoding errors
    in layer I and layer III audio and adds SSE polyphase
    support.
    * Fixed motion JPEG decoding bugs when padding is
    present before markers.
    * Fixed crash in SSE2 code when decoding MPEG-1 file
    odd width in macroblocks.
    * Fixed crash in SSE2 resize routine when doing 4-tap
    vertical resample with odd width.
    * Fixed swapped UVs in About dialog box. ^^;
    * Fixed sync errors in MPEG-1 playback when decoding
    an audio stream which flips the copyright bit between
    frames or switches layer III bitrates (VBR).
    * Fixed "Frame not found" errors in MPEG-1 decoder when
    GOP is longer than 128 frames.
    * Rewrote resampler clip determination code again.
    Hopefully this one will be Bug Free (tm).
    * Fixed spurious errors at end of operation when saving
    WAV file.
    * Outputted configuration files and job scripts now
    include the correct audio filename when a .wav file is
    selected through a script.
    * Fixed AVI segmented output creating short files when
    working from MPEG-1 source or when IVTC is active.
    * Image import filter wasn't caching frames.
    * Fixed a couple of Get*() script calls that were declared
    incorrectly internally and didn't work (thanks to
    Cyrius).
    * Blur filter now handles cropping properly.
  2. Anyone know a download site that works as all the mirrors seem to be constantly busy
