Hi all,
I used DVD Decryptor and Nero 5.5.9 to make a copy of the movie "Clerks". In Nero I used UDF1.02 as the partition,
turned off multisession and burned at 1x. The burn went fine and the DVD played on my PC's DVD player but not on my standalone Panasonic RV31. I used the DVDR supplied w/the burner(Cendyne), no brand listed on it.
Can someone please tell me the burn settings and brand of DVDR to use? Thanks!
I just bought a Cendyne and have an RV31 as well. I used the DVD-RW media supplied with the writer and it played out fine on the RV31 whereas it wouldn't play out at all on my Apex 1200.
I burned the disk with NeroVision. Simple I know but it worked. The settings were all default.
Correct Project and Sequence Settings for footage from Panasonic TM300?
By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 13:34 -
Panasonic AG-1980 - what settings for capturing?
By justin81 in forum RestorationReplies: 1Last Post: 7th Oct 2010, 18:07 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
Cant burn on -dvdr disc
By dnst3 in forum Newbie / General discussionsReplies: 11Last Post: 20th Dec 2007, 02:46 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 23:22
? Thanks!
