i'm trying to convert xvid 2 svcd but i have a problem, the xvid has some corupted frames so i tryed to remove them with virtualdub because i can't find anything to fix it !
before i removed the frames virtualdub gave me the message "Virtualdub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 13743 ms of skew from the vide steam. If this is unacceptable, decompress the *entire* audio steam to an uncompressed WAV file and recompress witha constant bitrate encoder. (bitrate:136.2 19.2kbps)
and after that if i played it through vdub the audio was not in sync.
so i think i need to do what it says but i'm not sure how?
and when i have i'm not sure how to multiplex them as tmpgenc comes up with illegal mpeg video steam ?????
so if anybody knows what to do or if you have any ideas please help
thanks
