  1. How do I create, from an .avi file a 2 CD VCD without turning the .avi to an .mpeg.
    May 2002
    GTA, Canada
    Well unfortunatley, unless you name is "GOD", in the words of Craig Tucker, you cant.
    You can try if you want, good luck though.
    -Dave
    werd
  3. so I have a avi file and I want to burn it to vcd and I dont want to lose any quality, how can i do it?
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Again: You can't. To create a VCD from an AVI source (or any other source that's not a VCD compliant MPEG), you have to encode to MPEG (see WHAT IS - VCD) according to some very strict rules. Since mpeg encoding isn't lossless, you'll end up with an MPEG that has a lower quality than the source, no matter how you try. Besides the inevitable quality loss in the encoding method, VCD resolution and bitrate also sets a limit to the end quality.
    /Mats
