Search is down, I'm sure this is answered somewhere.
What's a good audio encoder? The mpeg audio files I generate in TMPGEnc don't work with my DVDit.
If I encode them with Adobe Premiere they will work, but the sync gets off.
So I'd like to try another MPEG audio encoder and see if I can import them into DVDit.
For what it's worth, Adobe files had a .mpa extension and the TMPGEnc files were .mp2
Thanks!
If the audio file is indeed compliant just rename the extension to .MPA and it should work.
Originally Posted by furball6969
I will give it a try.
Thanks.
tmpgenc 4 audio no AAC encoder?
By sychern in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 21:06 -
downloaded video file, has buzzing audio when put into encoder
By efiste2 in forum Video ConversionReplies: 3Last Post: 22nd Jun 2009, 12:55 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:12 -
HC Encoder vs. audio
By awesomer in forum Video ConversionReplies: 7Last Post: 27th Jul 2008, 21:10 -
Windows Media Encoder broadcasts audio from one PC but not the other
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 12:48
