I read the posts on this and it seems pretty good.
I want to get an external burner for my birthday.
When I go to allmediaoutlet it does not list this burner but lists the 500drua.
Are these the same burners but one is in an external case?
I need something that will be easy to use and I can get cheap media and use in my dvd player ...pioneer dv 434
exactly the same but UL is external unit tather than internal
Thank you for the answer...
Are they good drives? I read bad things about them a few months ago..I am not sure if these are better..
I would love to get one but I am still learning and dont want it if I will have problems..The 9 posts on this forum about it all liked it which is good.
Scott -
It'll depend who you talk to, check all the reviews in the forum, but I have a 500a. In the first month or two after the release things were a bit choppy with the firmware and also software (such as Nero) needing to be updated to support the drive, but now things work hunky-dory. The only thing to consider is that it *is* a bit pricy; you might be able to get a drive that does what you need for less.
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
