i'm using a new hp external dvd writer...i recently switched my dvd writing software to ULead DVD Workshop... everything works great...until i reach the 100% burned mark, at which time, the DVD ejects and i get the error:
"Generic Error from CD/DVD recording software. Please make sure the drive is ready and try again. Error: TAO-2048-SPTI-00-02-05-72-03"
i've tried making 10 different discs with different video and menu styles...but all errored out...any ideas? I'm going bonkers with this! thanks ahead of time guys, i could really use the help!
update: re-installed software, and it still errors the same way...
anyone with some ideas?
anyone with some ideas? -
It may be your media. I had the same exact problem using the dvd-rw disc provided with my dvd burner. When I switched to verbatim dvd-r discs, I no longer had that problem. All of my burns were fine. Try switching media.
the sizes of the projects i haven't deleted that will NOT BURN are
428mb
1.8gb
3.4gb
4.15gb
also...i tried to use ulead to make an iso file to burn with nero but for some reason, even though i chose my external dvd burner and NOT by regular cd burner, nero asks me to insert a CDR/CDRW? and if i try to make an nero img file, it tells me that the nero img file can NOT be more than 2gb?
help anyone? -
i have been thinking about it and cant really give you a solution ..
other than try the burner in another machine (bad burner?)
or try another burner in your machine (bad "your machine"?)
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
