Virtualdub v1.5.0 is out:
http://www.virtualdub.org/
Here are the release notes:
Build 15584 (Version 1.5.0): [February 16, 2003]
[features added]
* Can add a single job to the batch list with syntax:
/p[input_file],[output_file]
* Filters are now loaded and unloaded on the fly to
circumvent TLS (thread local storage) selector limits.
* Cropping bounds can now be dragged via the mouse.
* Improved, friendlier crash diagnostics.
* Basic audio filter support (no plugin support yet,
though). The pitch shifter sucks.
* Increased accuracy of audio/video timing by switching
from microsecond to rational calculations.
* Changed font on dialogs to enable ClearType on XP.
[features removed]
* Deleted outdated 3x3 average filter -- it has been
superceded by "blur."
[bug fixes]
* New MPEG audio core (Priss) -- fixes decoding errors
in layer I and layer III audio and adds SSE polyphase
support.
* Fixed motion JPEG decoding bugs when padding is
present before markers.
* Fixed crash in SSE2 code when decoding MPEG-1 file
odd width in macroblocks.
* Fixed crash in SSE2 resize routine when doing 4-tap
vertical resample with odd width.
* Fixed swapped UVs in About dialog box. ^^;
* Fixed sync errors in MPEG-1 playback when decoding
an audio stream which flips the copyright bit between
frames or switches layer III bitrates (VBR).
* Fixed "Frame not found" errors in MPEG-1 decoder when
GOP is longer than 128 frames.
* Rewrote resampler clip determination code again.
Hopefully this one will be Bug Free (tm).
* Fixed spurious errors at end of operation when saving
WAV file.
* Outputted configuration files and job scripts now
include the correct audio filename when a .wav file is
selected through a script.
* Fixed AVI segmented output creating short files when
working from MPEG-1 source or when IVTC is active.
* Image import filter wasn't caching frames.
* Fixed a couple of Get*() script calls that were declared
incorrectly internally and didn't work (thanks to
Cyrius).
* Blur filter now handles cropping properly. -
Does it support vobfiles or should I continue to use the vdub mpeg2 mod??? on that note does it support mgeg2 I am not to cluey on all the tech jargon....
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 22:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 06:21 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
re: virtualDub
By merlie in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 15:50
