Hi I am new to this hobby so I am gonna need help now and then.
I have been quite successful in creating MPEG files from my Sony Camcoder. However the program I am using to author insist that the image size for VCD must be 352 X 240 or 352 X 288. My capture card settings are 192 X 144, 384 X 288 and 768 X 576. So that's the end of the road for me till I get a VCD compliant Video input card unless some one has a way out.
Appreciate your help.
Lx.
Hi
You don't need to capture at the exact spec, as you can convert the mpeg later with a program like TMPGEnc.
Capture as close as possible 384 X 288 ?, then load a VCD template into TMPGEnc.
This enables you to make compliant VCD's
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps) -
On 2001-09-06 06:11:09, letmeinforgodsake wrote:
Hi
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Hi,
Thanks a million.
Lx
Creating a DTS CD
By Xoanon in forum AudioReplies: 7Last Post: 22nd Mar 2012, 11:15 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
Creating TS from VOB??
By boofus in forum Video Streaming DownloadingReplies: 4Last Post: 29th Sep 2008, 18:02 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05
