I have a Question. I am ripping from a DVD using "TMPGEnc 2.59". I have my Bitrate set at 942bps, so that it will fit on a 80 min CD. The problem I am having is the time that "TMPGEnc" says it will take to do this process. The movie is 1hr 43min, but "TEMPGEnc" says it will take 61hrs.
Did I do something wrong, or is there a way for me to shorten the time, it is taking to do this? Thanks in Advance...
PS: would someone know of a program I can use, where I can covert a CD with Mpeg1 format to Mpeg2. My DVD Player will not play a CD with a Mpeg 1 format...
<link removed - no warez>
STEP BY STEP RIPPING GUIDES FOR YOU
MANY THANKS
DIDIDAVE -
I can't help you out with ripping a dvd. Some of the time needed to rip could be influenced by what speed processor you have. Just my $0.2.
Tmpgenc can convert mpg1 to mpg2. You will need tmpgenc plus. I don't think the free version of tmpgenc will do it.
Look at the guides. The guides here are great.
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
