http://www.dvd2svcd.org
17 feb 2003 version 1.1.2 build 1
- Bug Fix: If you have a decimalpoint , and thousandseperator . then the fileprediction factor for TMPGEnc would freeze on 1.500. The workaround in the former version is to switch the two symbols in controlpanel/regional options.
- Bug Fix: More regional option problems. If your Timeseperator differs from : the execution of CCE would fail too.
- Bug Fix: In Delphi 5 BoolToStr returned True or False but oh no, not in Delphi6. In Delphi6 returns 0 or -1 instead :( That meant that the use of Smartdeinterlacer failed. But what's worse, TMPGenc might fail sporadic too :((
- Bug Fix: A combination of Batch running + Frameselection + Subtitles would cause the subtitles not to be extracted and used. Fixed.
- Bug Fix: IMDB Additional Data was not reset between movie selections. Fixed.
- Bug Fix: Number of CD Images and Sourcetype wasn't always written in SVCDInfo.txt. Fixed.
- Bug Fix: AVI2SVCD used a wrong ota-parameter syntax for BeSweet
- Bug Fix: AVI2SVCD: EAccessViolation Access violation at address 00623FFF fixed.
- New Feature: Support for Canopus Procoder 1.01.35.0 (maybe other versions too, but I haven't tested that)
