Hi i got a film on avi file, and i need to extract a 44hz wav files before i make a vcd, but it keeps saying missing compressors, this is the first time this has happened.
this film has some wierd codecs, divx wouldnt work, i had to dowload these differnt ones.
so i need to know where i can get extra codecs/compressors for virtual dub. Im at uni atm, when i get home, ill post teh names of those codecs.
thanks.
hi the audio codec used on the avil film is
ac3 (0x2000) "Dolby Laboratories, Inc" -
That has ac3 (dolby digital) sound. You will need to save it as a wav file using direct stream copy. Rename it as ac3. Then use headac3he to convert to a 2 channel wav file.
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 06:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
