This is getting annoying. Seemed to have solved my previous frame-freeze problem with TMPGEnc, now I'm getting other problems.
Runtime errors, an error to do with kernal32.dll, and some other stuff.
(EDIT: Heres one of the exact error messages: "Read error occured at address BFF7A125 of module kernal32.dll with 0078FFA0", then after that it pops up with "Failed to refer to tab No. 0")
When I first got these errors I simply formatted my harddrive. Now, here I am a few hours later, a clean install of windows, etc. and I'm getting the same problems - but to a lesser extent. Before the video wouldn't encode at all - now I get an error, but if I try again it works.![]()
Using the same version of tmpgenc as before, and theres pretty much no software installed yet.
What can i do to fix this?
BTW... I've seen many posts on this subject, but since the search function seems to be out of action, I can't go looking for em![]()
Black Bar problems with TMPGEnc
By ereiamjh in forum Video ConversionReplies: 5Last Post: 22nd Mar 2010, 10:32 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
