Hello,
I have a DVD which has NTSC MPEG-1 menu and PAL MPEG-2 main video file. I am trying to convert the menu into PAL format for consistency.
Is there any utility or software that can do so?
well, let's put it easier.
If I have a complete NTSC format DVD5.
What is the easiest way to convert into a brand-new PAL format DVD5? -
Hi,
I have a few NTSC dvd's as well (mostly thos IMAX ones and a couple of doco's).
I've had little success in converting directly between NTSC and PAL. You might have more success going from NTSC to Film (24fps) and then from there to PAL....there is a tool out there that can do a half decent job but the name escapes me (I found it here in the forums once via a google search).
The alternate is to mess with the signal that comes from the back of your player. You can split the composite signal into RGB and Sync signals and then re-combine them into PAL...you TV needs to support 60Hz signals to get this to run though (a lot do). You can buy a box that does this for you but it is around AU$500. Alternatly you can spent $120 on a cheap DVD player....most can play NTSC DVD's on Pal TV's. -
or try this....
https://www.videohelp.com/forum/userguides/100719.php
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 17:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
