I just got 8 Mile in Xvid AVI format. I have the Xvid codec and the Nimo Codec Pack. When I watch it, its got a green screen over it. Ive tried to encode it and I get a green screen. I tried VDub but when I tried to play the finished product out of VDub it didn't play at all. Can anyone help me?
Thanx
Stoked
It's just a case of trial and error when installing the Xvid codecs.
Remove the Nimo pack for a start as it is a waste of time (in my experience anyway) and reinstall the codecs you actually need, divx5.02, Xvid, ac3 etc..
I found 3 different xvid codecs on kazaa all different file sizes, one was called alpha, this codec works with all my films, (inc 8 Mile) and seems to plough on through bad frames when encoding too (could be either a good or bad thing!!)
Reinstall your codecs one by one then make a note of the date's of the dll files, that way you will know what codecs you are using actually work for you. -
Hey, I did what you said(Uninstalling all the codecs and reinstalling them) and it worked. Thanx alot for your help.
Stoked -
I have a alternative way of dealing with Xvid's with Ac3; read my old posts. I'm busy making a guide converting Xvids with Ac3 using Panasonic MPEG1 & Cillers Ac3 tool. I promise you; this way works 99% !
D.C 8)" Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon. -
The xvid I have now plays but I think I have a bad frame or something in it because when I went to encode it, it just freezes near the end but the audio still goes on. How do I fix this?
Stoked -
Try this guide here:
https://www.videohelp.com/forum/userguides/142555.php
D.C. 8)" Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon.
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 16:47 -
Xvid encoding
By fester77 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2011, 08:19 -
Quick XViD Encoding?
By shorto in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2008, 04:54 -
Encoding with Xvid.
By Felo in forum Video ConversionReplies: 1Last Post: 26th Aug 2007, 01:38 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 18:12
