Virtualdub talks about "Copying Source Frame to Clipboard" and I'm assuming that means the current visible frame? I'm wanting to capture one of the pictures in a video with a printscreen so I can paste into Photoshop and make a cdrom label for my copy. I tried the Ctrl/1 and Ctrl/2 and it doesn't seem to put anything into the clipboard ..... am I misinterpreting what it's supposed to do? Which program will do the job I need. Thanks much.
Gritz
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
You can capture frames from computer screen with Paintshop. Just start the program, minimize it and press the buttom right from F12...i don't know it's name couse i have german kyboard.
Then open Paintshop and paste it for further editing. -
I think he is talking about the printscreen button. Anyway, you are right, the Cntl +1 button does not work, but the menu selection (by mouse) does work in Virtual Dub.
Hello. -
What is your source material? If the cd-rom you're making is from a DVD rip or something similar I'd recommend playing the file with your DVD software and using it to capture the picture you want. My DVD software seems to play anything so long as I have the appropriate codec installed so this may be your best option.
Regards,
NitemareEven a broken clock is right twice a day. -
Yes copy source to clipboard is correct. Then in photo shop select file then new. From the just put your curser inside your new project box right click and paste and your done. Pretty darn easy.
I think what he wants to do it "copy" a screen that he is watching in a movie. This is simply not as easy as pressing the "print screen" button in most divx/mpeg movies. If you just try and do that all you get is a black screen. What you have to do is open a movie in windows media player and then goto "tools/options/performance" and then drag the video acceleration button to "none", click apply and now you can take screenshots of the movie in windows media player. To do this simply press "alt +enter" in windows media player (to make it full screen) and now you can press the print screen button to take a screen shot of the movie. Then simply open your favourite paint program and paste the screen shot
I just play the movie on powerdvd then click the capture button to save the still I want as a bitmap (you can convert it to jpeg later)
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
WOW .... What a resource you guys are ..... great help, and so quick! I will definitely try to make some contributions back when I get a little more proficient. I appreciate greatly ALL the replies and you can bet I will try each one of them ........
Thanks again .... Gritz"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
full screen high def video playback program
By syeager in forum LinuxReplies: 4Last Post: 11th Jun 2008, 10:39 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20 -
Screen Capture Program ?
By Endemoniada in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 15:45
