I capture pal TV at 320x480 and 25 fps. What's the best method to deinterlace and resize to 320x240. I use the high vert res to preserve all fields during capture.
I read about the inverse telecine method for ntsc which involves capturing at 29.97fps and then ivtc in virtual dub. This gives a non interlaced end result with all fields intact. Is there any such trick for pal capture?
As of now i deinterlace and resize in virtualdub. Gives good results, but i'd like to know if it's possible to use ivtc and get better results i.e. preserve all fields and not average them like in the case of deinterlace.
Results 1 to 13 of 13
PAL is a dream to deinterlace, especially for what you want to do: all that's necessary is to split the fields and throw one of them away.
Load the standard (internal) VirtualDub deinterlacing filter and select Discard Field 1 (or Discard Field 2). That's it. The process is the same regardless of whether the source originated from film or tape.
... but surely you're capturing at 352x576 (PAL 1/2-D1) rather than 320x480, aren't you? Because 320x240 isn't a legal PAL VCD frame size -- it needs to be 352x288 when you're done with it, unless you're making a PAL DivX of course. -
keithsebastian,
First of all I would not recommend groyals' method of deinterlacing especially if you want smooth video, try blending instead. Second there is no way to IVTC a PAL video source, this is exclusively an NTSC procedure. There is however a way to have full frames in a PAL video stream, ie. 25 fps progressive, but the video source already has to be progressive. Also groyal was right about capturing at 320x576, not 320x480 which is NTSC. -
Hey groyal - thanks for the info. But if i was to throw away one field, then i would capture at standard resolutions in the first place viz. 320x240 or 352x288 (PAL). It gives the same result with lesser effort. I'm trying to keep both fields.
I want to clarify whether case 1 is better'n case 2
case1 : capture at double vertical resolution (any standard) then deinterlace and then resize to required (lower) vertical resolution.
case2 : capture at lower vertical resolution (any standard) . No need to deinterlace as one field is permanently lost. -
keithsebastian,
1. What are you trying to convert to?
2. Are you on AIM or MSN Messenger, and I can probably help you faster.
-Epi -
Epi -
1. I'm capturing from pal tv to 320x480, resizing it to 320x240
as mentioned in the previous post. AND encoding to VCD with
320x240 video window centered in a 352x288 PAL std.frame.
(i do this to compensate for tv cropping)
2. No i'm not on any IM
Thanks for the help. -
keithsebastian,
Try capturing at 480x576, to get a sharp capture which will result in a sharp VCD encode. You really don't have to worry about cropping especially if you are capturing from a TV Capture Card. It captures the whole picture especially more than what you see on your tv.
Use this TMPGEnc template to to encode your VCD:
object TMPEGConfigFile
MPEG.Text = ''
MPEG.WizardCategoryName = ''
MPEG.WizardSubFormatName = ''
MPEG.WizardCaption = ''
MPEG.WizardDescription = ''
MPEG.WizardTargetMedia = MPEGConfig_TargetMediaType_Unknown
MPEG.WizardAutoCalcVideoBitRate = False
MPEG.WizardAutoChooseList.EnableVideoSize = False
MPEG.WizardAutoChooseList.VideoSize = <>
MPEG.WizardAutoChooseList.EnableVideoGOP = False
MPEG.WizardAutoChooseList.VideoGOP = <>
MPEG.OutputStreamType = MPEG_OutputStreamType_System_VideoAudio
MPEG.OutputStreamType_ReadOnly = False
MPEG.Video.StreamType = MPEGVideoEncoder_StreamType_MPEG1
MPEG.Video.StreamType_ReadOnly = True
MPEG.Video.Width = 352
MPEG.Video.Width_ReadOnly = True
MPEG.Video.Height = 288
MPEG.Video.Height_ReadOnly = True
MPEG.Video.YUVFormat = 1
MPEG.Video.YUVFormat_ReadOnly = False
MPEG.Video.DC_prec = 0
MPEG.Video.DC_prec_ReadOnly = False
MPEG.Video.VideoEncodeMode = MPEGVideoEncoder_VideoEncodeMode_Progressive
MPEG.Video.VideoEncodeMode_ReadOnly = False
MPEG.Video.FrameRate = 3
MPEG.Video.FrameRate_ReadOnly = True
MPEG.Video.AspectRatio = 8
MPEG.Video.AspectRatio_ReadOnly = True
MPEG.Video.RateControlMode = MPEGVideoEncoder_RateControlMode_CBR
MPEG.Video.RateControlMode_ReadOnly = True
MPEG.Video.MaxBitRate = 0
MPEG.Video.MaxBitRate_ReadOnly = False
MPEG.Video.MinBitRate = 0
MPEG.Video.MinBitRate_ReadOnly = False
MPEG.Video.MinAvgBitRate = 0
MPEG.Video.MinAvgBitRate_ReadOnly = False
MPEG.Video.CBR_BitRate = 1150000
MPEG.Video.VBR_MultipassVBRAlgorithm = MPEGVideoEncoder_MultipassVBRAlgorithm_MultipassCQ
MPEG.Video.VBR_AvgBitRate = 1957000
MPEG.Video.VBR_MaxBitRate = 2534000
MPEG.Video.VBR_MinBitRate = 1163000
MPEG.Video.VBR_MaxPassCount = 2
MPEG.Video.VBR_Quality_P = 0
MPEG.Video.VBR_Quality_B = 20
MPEG.Video.VBR_EnablePadding = False
MPEG.Video.MVBR_MaxBitRate = 3000000
MPEG.Video.MVBR_MinBitRate = 0
MPEG.Video.MVBR_Quality_P = 0
MPEG.Video.MVBR_Quality_B = 20
MPEG.Video.MVBR_EnablePadding = False
MPEG.Video.AVBR_Quality = 50
MPEG.Video.AVBR_MaxBitRate = 3000000
MPEG.Video.AVBR_MinBitRate = 0
MPEG.Video.AVBR_EnablePadding = False
MPEG.Video.CQ_Quality = 50
MPEG.Video.CQ_Quality_P = 0
MPEG.Video.CQ_Quality_B = 20
MPEG.Video.CQ_MaxBitRate = 3000000
MPEG.Video.CQ_MinBitRate = 0
MPEG.Video.CQ_EnablePadding = False
MPEG.Video.VBVBufferSize = 0
MPEG.Video.VBVBufferSize_ReadOnly = True
MPEG.Video.GOP_SeqHeaderInterval = 1
MPEG.Video.GOP_SeqHeaderInterval_ReadOnly = True
MPEG.Video.GOP_I_FrameCount = 1
MPEG.Video.GOP_I_FrameCount_ReadOnly = True
MPEG.Video.GOP_P_FrameCount = 4
MPEG.Video.GOP_P_FrameCount_ReadOnly = True
MPEG.Video.GOP_B_FrameCount = 2
MPEG.Video.GOP_B_FrameCount_ReadOnly = True
MPEG.Video.GOP_BitStreamForEdit = False
MPEG.Video.GOP_BitStreamForEdit_ReadOnly = False
MPEG.Video.GOP_MaxFrameCount = 15
MPEG.Video.GOP_MaxFrameCount_ReadOnly = True
MPEG.Video.QuantizeMatrix_Intra_ReadOnly = False
MPEG.Video.QuantizeMatrix_NonIntra_ReadOnly = False
MPEG.Video.Profile = 4
MPEG.Video.Profile_ReadOnly = False
MPEG.Video.Level = 8
MPEG.Video.Level_ReadOnly = False
MPEG.Video.VideoFormat = 2
MPEG.Video.VideoFormat_ReadOnly = False
MPEG.Video.DisplayWidth = 0
MPEG.Video.DisplayWidth_ReadOnly = False
MPEG.Video.DisplayHeight = 0
MPEG.Video.DisplayHeight_ReadOnly = False
MPEG.Video.MotionSearchSpeed = MPEGVideoEncoder_MotionSearchSpeed_HighCQ
MPEG.Video.MotionSearch_AlwaysHalfPel = True
MPEG.Video.UseFloatDCT = False
MPEG.Video.QuantizeMode = False
MPEG.Video.QuantizeModeVal_Intra = 35
MPEG.Video.QuantizeModeVal_NonIntra = 35
MPEG.Video.YUVBasicYCbCr = False
MPEG.Video.QuantizeMatrix_Intra = {
081013161A1B1D22101016181B1D222513161A1B1D22222616 161A1B1D222528
161A1B1D202328301A1B1D202328303A1A1B1D22262E38451B 1D23262E384553}
MPEG.Video.QuantizeMatrix_NonIntra = {
10111213141516171112131415161718121314151617181913 14151617181A1B
14151617191A1B1C151617181A1B1C1E1617181A1B1C1E1F17 18191B1C1E1F21}
MPEG.Audio.StreamType = MPEGAudioEncoder_StreamType_MPEG1_Layer2
MPEG.Audio.StreamType_ReadOnly = True
MPEG.Audio.SamplingFrequency = 44100
MPEG.Audio.SamplingFrequency_ReadOnly = True
MPEG.Audio.ChannelMode = 0
MPEG.Audio.ChannelMode_ReadOnly = True
MPEG.Audio.CantUseMono = False
MPEG.Audio.BitRate = 224000
MPEG.Audio.BitRate_ReadOnly = True
MPEG.Audio.CalcCRC = False
MPEG.Audio.CalcCRC_ReadOnly = False
MPEG.Audio.OriginalFlag = False
MPEG.Audio.OriginalFlag_ReadOnly = False
MPEG.Audio.CopyrightFlag = False
MPEG.Audio.CopyrightFlag_ReadOnly = False
MPEG.Audio.PrivateFlag = False
MPEG.Audio.PrivateFlag_ReadOnly = False
MPEG.Audio.EmphasisType = 0
MPEG.Audio.EmphasisType_ReadOnly = True
MPEG.System.StreamType = MPEGSystemEncoder_StreamType_MPEG1_VideoCD
MPEG.System.StreamType_ReadOnly = True
MPEG.System.EnableCommentText = False
MPEG.System.CommentText = ''
end
Make sure you go into settings under settings and double-click on Deinterlace and select "Even-Odd field (field, animation adaption 2)" This will automaticaly choose between which frames to encode to allow for the smoothest possible encode.
-Epi -
And I wouldn't recommend relying on the revolutionary new Epi-VCD template to deinterlace your video, either. It's really just a matter of common sense.Originally Posted by Epi
Deinterlacing methods can be divided into two types: frame-based methods, which are like wearing a band-aid to mask the symptoms of a disease, and field-based methods, which are like treating the disease itself. Blending is an example of a frame-based method. The two fields are smeared together to eliminate the combing artifact, but you end up producing a new artifact -- ghosting -- in its place.
Contrary to what has been said, this does not result in smoother motion. If the two fields are significantly displaced (as they would be during a horizontal pan) the edges along the direction of motion are smeared causing the video to "jerk" as the camera moves from left to right. This is especially visible on NTSC film sources since twelve of the fields per second were interpolated to begin with. Essentially you're adding a smear to a smear and hoping they'll average out, but actually they reinforce each other, making the smear much more obvious.
In field-based deinterlacing you attack the problem at its source. Each PAL field has a time displacement of 1/50 second relative to the previous field: each frame contains a pair of pictures from different moments in time. When you split the fields, each frame is half the original vertical size but contains the same amount of picture detail -- you just have one frame per field now (twice as many as you need) which is why you throw one of them away. Nothing gets smeared in the process, so the video is smooth and fluid in addition to being fully deinterlaced. You can then resize the frame vertically to bring it back to its original dimensions if you like.
When you capture in full vertical resolution you're preserving both fields, but the fields themselves are only half a picture high. They're interlaced together to "stack" them for sequential display, but that doesn't change their vertical resolution -- there are only 288 lines of detail in a field whether you view them separately or together. This is why throwing one field away and line-doubling the other doesn't degrade picture quality, while smearing the two fields together (blending) certainly does.Originally Posted by keithsebastian
But if you can avoid the need to deinterlace by capturing at half vertical resolution to begin with, by all means do so. What's the point of capturing a field you don't need only to worry about getting rid of it afterwards? The vertical resolution is the same whether you capture one field or two -- don't let the fact there are two fields interleaved together fool you into thinking the picture has more than 288 lines of detail. -
groyal,
All the template does is lock the PAL VCD settings into TMPGEnc, it does not have anything to do with de-interlacing, and I'm not even trying to make an EpiVCD template (thats just ridiculous). You have to lock the frame rate or when you select the de-interlace that i suggested he use, it will change it to 50fps which is out of VCD standard. If you only encode the first (or second) field of every frame you will get jerky motion.
-Epi -
Persistence pays - I think I found the answer. I tried Donald Graft's smart deinterlacer for vdub. This one does deinterlacing
based on motion detection i.e. only when interlace artifacts
are present, and not all the time. Hence both fields are preserved
when deinterlacing is not required like in low motion scenes.
Groyal - U should give this a try. It's better than throwing away
one field.
Epi - Thanks for the template. One more question - Will disabling
'detect scene change' give better results for high motion videos?
As vcd bitrate is low i have a feeling that extra I frames that
result from enabling this setting will only degrade overall quality. -
If you turn on "detect scene change" you may not end up with a VCD Compliant MPEG. Sometimes this causes slowdowns in your videos especially when you fast forward or rewind.
-Epi -
I'm aware of it, thanks, but I wouldn't have need for it myself as I already know how to deinterlace.I tried Donald Graft's smart deinterlacer for vdub. This one does deinterlacing based on motion detection i.e. only when interlace artifacts
one field.
That being said, it's a fine filter, but it's still just a band-aid because it masks the symptom without treating the disease. At best it smears less of the picture by smudging only the areas where artifacts are present, but it smudges them nevertheless.
I realize it's counterintuitive, but if you have two pictures stacked on top of each other to form an image, throwing one of them away reduces the height of the image but it doesn't change the vertical resolution. Two pictures are two pictures whether you arrange them side by side, top to bottom, or in tiny alternating strips. No matter how you arrange them, each picture has only 288 lines of detail. Throwing one of them away sacrifices nothing.
If the differences between the pictures are significant, blending them together will cause some amount of ghosting no matter how carefully it's done. Even if you blur only the portions of the picture where the ghosting is the most obvious, the blurring artifact you're creating is as bad as the combing artifact you're trying to get rid of. It's inevitable.
Now, I can tell you're not buying any of this, and that's okay. Remember this discussion a year or two from now when you're cringing at the sight of one of your earlier pieces wondering "man, what was I thinking when I made that?" :)
(How to) Inverse Telecine
By Cherbette in forum RestorationReplies: 16Last Post: 17th Nov 2011, 14:24 -
Inverse Telecine Anime (Death Note)
By Corpsecreate in forum Video ConversionReplies: 16Last Post: 7th Oct 2011, 03:55 -
Frasier DVD to iPod Inverse Telecine Help
By jmsajdak in forum DVD RippingReplies: 1Last Post: 4th Sep 2008, 10:16 -
PAL Inverse Telecine?
By Anakin in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:34 -
Inverse Telecine, IVTC
By kitty in forum GlossaryReplies: 1Last Post: 10th Jan 2008, 22:40
