In MMB i can burn a cd but i cant rip one. Idk if im doin it wrong or whatever. And since we are on the topic of cds, how do i copy a multi-sessioned b/c in toast it wont let me, it only allows me to copy the first session. Third, how do i burn a muti-sessioned cd.
less than jake, wooo hooo!!!!!
Well, I don't know answers to your 1st and 2nd questions, but I'm pretty sure I can answer your 3rd question.
With Toast (I have 5.1.4, I believe) this is what I do to burn multi-session (at least the kind I think of, may or may not be the same as your idea).
Just put your data in the Toast window, click "burn" and another window comes up with what speed, etc. It has the Aqua "burn" button in the lower-right hand corner. Right above that is another button that should say "Burn Session" or something like that. Click that, and then you should be able to burn another session later.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
