Ok I have tried many software but none seem to work. What i want to put on dvd is a 16:9, 23.976 with 3:2 pulldown, w/ac3, video file. 4000 cbr.
Software Ive tried:
1. DVD Workshop trial. Outputs all movies in 4:3, i need 16:9.
2. MyDVD (old 2.3). It just sucks basically. It wont even accept the video file.
3. Spruce up. Trial doesnt support ac3. dont know about the 16:9.
4. IfoEdit. Very confusing program, just not able to figure out how to get anything but some vobs and isos that had timing problems.
5. Few others. Same problems as above.
Not to mention the fact that all of these programs recognize my file as 1:35 as opposed to the 1:59 that it actually is, makes HUGE problems for finding chapters. Yes at the same time windvd and realplayer find the right lenght of the file.
What is a program or set of many programs that can get hte job done? Help please
Not 100% sure but RealDVD might do the trick...as long as the whole project is 16:9.
Also Sonic Scenarist would do it. depends how much you want to spend, ReelDVD would set you back, at the very least 900 - 1000 us$ and Scenarist would be 20x that.. Most likely cheaper ways to do it but none that i can think of-Bish0p
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 05:36 -
authoring software
By anasa in forum Authoring (DVD)Replies: 4Last Post: 31st May 2011, 20:19 -
authoring software.
By Kibble in forum Authoring (DVD)Replies: 1Last Post: 4th Mar 2008, 11:30 -
Best DVD authoring software?
By skybadger in forum Authoring (DVD)Replies: 8Last Post: 16th Aug 2007, 06:11 -
Help on what authoring software to use
By neosatusneu in forum Authoring (DVD)Replies: 5Last Post: 6th Jun 2007, 19:57
