  1. Ok.... I have 3 svcd's that I'm trying to link together but parts 2 and 3 were cut so not to miss the action. Now when I cut the individual movies so that they can link together without duplicating frames......the audio goes out of sync once it reaches the spot where they were merged. Can anyone tell me what I am doing wrong??
  2. I guess I am asking a foolish question? Ok next question... How do I merge 3 mp2 files??
  3. Well, my guess is that you should convert the 3mpg files into divx. Then use VirtualDub to make one divx out of it. ( "append avi segment")
    And then reconvert it to VCD.
    Probably this is a very stupid solution, but it works
  4. :P Well I did some more reading and Wah LAH! svcd to dvd-r
    https://www.videohelp.com/forum/viewtopic.php?t=142742 IT WORKS!!
    joined the 3 svcds using the thread above!!
    only thing I did different....(probably doesn't matter) was convert the mp2 files to AC3 using BeSweet
