I've ripped dvds before and had no problems
Just recently i've been having problems putting the video file onto the project wizard on TMPGenc
I've loaded the film up using dvd decriptor
Then AVI'ed it using DVD2AVI
Then gone on to encode it using TMPGenc
The audio file loads up as usual
But when looking for the video file i have to look under "all files" to access it
When i do this and try and put it in this way It says
" d2v file cannot open or is unsupported"
Can somebody pls help
Make sure you have the DVD2AVI complete ZIP, and that you unzipped it to
where your TMPGEnc is located, this should unpack the DVD2AVI.VFP plugin
file, and enable TMPGEnc to detect D2V files.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 14:23 -
Why does converted HD to SD file show video as letterbox using Tmpgenc?
By Endoking01 in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2010, 21:37 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23
