hello,
i'm capturing from my panasonic dv cam via firewire using adobe premiere 6.
so, after it finished, i have the video on my harddrive in MS DV Codec.
but the problem is, that i get a "shifted" effect when i have fast camera movements.
is this a capturing problem or a codec problem?
is it possible to use another codec when capturing via firewire?
here is a sample:
It's because you are looking at an interlaced image on your computer monitor. Premiere does not de-interlace the image when shown on your computer monitor so anything with movement will show visable interlace lines. There is nothing wrong with the picture. The video will look normal on a regular TV screen. (When exported back out to DV or DVD.)
thank you.
ok, but i want to produce an mpeg or avi(divX) to be viewed on computers only.
is there any way for a workaround?
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
KMPlayer and FFDShow deinterlace - how to get "bob" effect working?
By ANOther1676 in forum Software PlayingReplies: 3Last Post: 18th Feb 2011, 07:47 -
Paint Shop Pro - "Sin City" effect?
By stantheman1976 in forum ComputerReplies: 5Last Post: 30th Apr 2009, 15:56 -
how to create "thinking" effect(when someones voice plays in head
By bojadada in forum AudioReplies: 3Last Post: 20th Dec 2008, 12:23 -
Eliminating "Tearing" effect in 2D games with Vsync & Triple
By retroborg in forum ComputerReplies: 1Last Post: 17th Dec 2007, 10:50
