Im useing CCE SP Version 2.66.01.07 to encode my video to dvd, and when its done im useing Sonic MyDVD to author it but when i put it in there it always says that MyDVD will have to encode my video to be dvd compliant. Anyone know the reason why its doing this. When i encoded it i pick dvd complian. If someone uses it maybe you could show me what settings to use. Here is what settings i am useing if it helps any
Code:http://www.jsmooth.netfirms.com/settings1.jpg http://www.jsmooth.netfirms.com/settings2.jpg http://www.jsmooth.netfirms.com/settings3.jpg
comon now nobody uses this to encode??? Then what can i use to author a movie encoded with cce, cause dvdit or mydvd wont do it
Please wait a few days before bumping your post.
CCE can't resize so is your source in dvd resolution?
Mydvd will ALWAYS reencode the audio to pcm audio(around 10 MB/minute instead of compressed audio mpeg/ac3 audio 2-4MB/minute) -
Try checking "Add Sequence End Code", and "Upper Field First" in your video settings. Also, how long (time wise) is your source video? Maybe encoding at 8000kbits is too big to fit on one DVD-R so the program has to re-encode it. (Although I don't know why it would do that.)
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 19:20 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
Is the 'academic version' different from the commercial version of Vegas 8?
By jbigfoot in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2008, 01:19 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
