Just trying to compare time to convert a 300MB .avi file to Mpeg-2 in
TMPGenc. I am running XP 2100 Athlon with 768 Meg of ram and it is taking a good 2.5 to 3 hours plus to encode this. Is this about right.
Any inputs would be appreciated. I am using normal settings for the most part with a few HQ on some.
It is not possible to answer this question as you do not give the length of the movie, or the bitrate you are using. We would also need to know the method of encoding, CBR, 2pass VBR?, and your setting for motion search precision. There are other factors that would affect encoding times, but these are the main ones.
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 06:29 -
Trying to convert AVI to MPEG file smaller then 4gig
By Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 12:01 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
