  1. Hello
    I have many problems with Ffmpeg-e and I think that that comes from all the installations and désinstallations from the preceding versions. Thus I would like to know if it is necessary to install Ffmpeg on root or how to remove the preceding files.
    And how to make a clean install of FFmpeg.
    Thank you for your assistance..
    Michel
  2. Nothing for me ?
    please i need help...
    thanks
    michel
  3. - Trash other versions and install 0.0.6g by copying it in your Applications folder.
    - Copy the engines installer in your hard disk and run it once .
    - While running the installer it will require your root login password.
