ive been trying to follow the instructions on how to copy a dvd onto one disc from baldrick on the front page but having few problems.ihave succesfully ripped the dvd and put it onto hardrive then convert with dvd2one.i seem to behaving problems when trying to burn image onto dvd disc.i have a pioneer 104 and nero and recordnow burning software any help on this last part would be great, cheers in advance bodgeit.
move all the files that dvd2one created in to a folder called "VIDEO_TS", and create a folder called "AUDIO_TS".. there will be no files or folders in the AUDIO_TS folder..
then follow these instructions for burning your dvd movie;
http://ifoedit.wh.fr0zen.com/primo.html
by the way, recordnow & primo are the same thing.. (very few differences) -
@jeex
thanks mate sorted at long last,it was the audio and video files that i was missing ive been just trying to copy the files straight over, thanx 4 the quick reply, no more wasted discs!!!!!!!!!
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
