I have a Toshiba SD-220e chipped for multi-region and have tried many different VCDs (and SVCDs) and they are all out of sync, with the exception of cartoons which are fine. The time between action and sound varies between 5seconds and a fraction of a second. I have tried different media and burning at different speeds but it made no difference. The source files are fine and are in sync when I play them on my PC (using Mediaplayer or PowerDVD). Whats strange is the fact that cartoons are in sync? Any ideas? The player is still under warranty, so I could take it back. Thanks in advance.
I have a Tosh SD210e and my SVCDs used to play out of sync despite firmware upgrade when using menu in Nero.Without menu played fine.Very frustrating!Then I found Ulead DVD Movie Factory which played in sync with menus.I'm now using Movie Factory 2 authoring DVDs so I don't use SVCD much anymore.Give DVDMF2 a try.There is a full working demo.
Toshiba sd 7200 no sound after hack
By Godiva in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jan 2010, 17:11 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 11:19 -
Help with a sound issue on a Toshiba SD-6100
By hhcup in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Apr 2008, 10:06 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 10:31
