Recentley I have switched from using DVDx 2 to using eazy VCD.... eazy VCD gives me a much better picture quality but when using it I notice it only gives me half of the mvoie... I dont know what I am doing wrong...if anyone can tell me the settings to use or what I screwed up on it would be greatly appreciated... thank you
I Suggest you try following my Complete Guide section on Eazy VCD and see
that you follow it, if it worked for me, it should work for you too
Complete DVD Backup Guide v2.1
http://www.digital-digest.com/dvd/articles/dvdtovcd/
Complete DVD Backup Guide v2.1 - Eazy VCD section
http://www.digital-digest.com/dvd/articles/dvdtovcd/direct6.htmlEmail me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
