(I don't know what warez is, but if my question applies to it sorry)
Is there anyway to play a burned DVD on the PS2 without buying upgrades or any other sort of thing? If you can help please do.. thanks.
Results 1 to 16 of 16
You'll probly have to get a mod chip for your PS2. I think that the PS2 can only play commercial discs. I don't know much about it since I don't have one but, there are some places that sell mod chips for playing copied dvds.
Originally Posted by kpc180
Thanks, I am trying to play a backup movie. Not a game. It just says that the disk can't be read.
Depends on the media. What type, DVD-R, DVD+R, etc.
Does the DVD work in your DVD player or computer? What type of DVD format is it? -
I only recently started tests with the PS2. I used both a pioneer DVD-RW and a Memorex DVD-R. The later worked but took slightly longer to start. The former woulnd't read (both were burned in Nero). PS2 Is unmoded and I just used the standard DVD video template in Nero 5.10.7b
Ps2's i think will only play exact copies of movie, so if you reencode or anything i dont think it will play, but again im not too sure. All of the movies that i did using dvd-r discs were exact copies and worked perfectly.
PS2 will play re-encoded movies if they were authored right. Re-encoding has nothing to do with it not playing. Unless you are trying those non-compliant DVDs, VCD on DVD or SVCD on DVD. That will not work.
Like Shabubu said, the media and DVD-R will be fine. Also what version PS2 matters. Some are more forgiving than others. -
Will this work for a v1 non-modded PS2 because i am having problems but it might have been the vcd thing so i was just wandering if you could tell if it works for +R discs before i waste more blank discs.
Yea the dvd I am trying to use is a DVD+RW burned through Sonic My DVD with a Phillips burner and it is not a exact copy of another movie it is clips of things I have downloaded off the internet.
Ps2's play copies of dvd movies without needin a modchip full stop.
After that a lot of variables come into play ie version of ps2, media etc.
I have a ps2 v7 wit magic 3. I use smartripper, dvd2one and prassi for all movies. I burn to ritek silver top at 2x on 104 wit 1.31 firm. All perfect.
In my expierence never use nero for anything. Prassi or RecNow Max only.
go here- it is the home of the ps2
http://www.ps2newz.net -
i have a version 4 and version 7. dvd+rw does work on the v7 but not the v4. i personally havent tested anything else because i just got my burner.
i have a PS2 model v7 and i can play DVD-R DVD+R and DVD+RW movies with no problem. and you don't need a modchip in order to play backed up movies.
i read that Sony had changed the laser block of the PS2 and that is why older version of the PS2 have a hard time reading burned DVD media beside DVD-Rs
i ran a search on google and found this if you want to check what PS2 version you have
http://www.brown-computers.com/ps2-versions.htm
Originally Posted by Star Warrior -
I author my dvd-r's using Nero using the dvd(rom) UDF/ISO setting.no multisession.Under iso tick iso level 1 & iso 9660 and untick the joilet box.Under UDF tick the box that says "force dvd compatibility mode(required for xbox Tm)" and this greys out the udf physical partition boxes.Now click on new and assemble your compilation and write.
THIS has worked on dvd's I have done and tested on 4 of my friends PS2's (unchipped),they all played perfectly except that NTSC films were in black & white as Playstations (pal ones) cant seem to handle NTSC.
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 18:32 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 22:36 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
Ps2 to Laptop
By sk8erkho in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2007, 11:31 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 09:02
