Hi have tested the new forty two 1.5 on Ice Age PAL version...
I get these files when it has finished..
The mpv is only 508 long and it is not the hole movie..maybe 20%
ICE_AGE.mpg.ac3 - 107 MB
ICE_AGE.mpg.idx - 4 k
ICE_AGE.mpg.sub - nul k
biles.mpv - 508 MB
What is wrong??...and yes I have selected DVD in the menu...
Hope you guys can help....
This usually happens when the title it is trying to encode does not contain the whole movie, or the disk is dirty.Originally Posted by haribo
Play the dvd title in vlc...is it the whole movie? FF thru...does vlc for some reason gag or choke?
Computers are a *whole lot less* tolerant of imperfections on the dvd (as i'm finding out trying to convert DVDs that my kids have "played with" heheh)
-K -
i tried making a pal dvd to vcd, and it wont play on my dvd player. is it because it is pal?
That is correct. PAL mode is for PAL equipment. Depending on your player and TV you might be able to get it to work.Originally Posted by ryanremigio
If your dvd player can do progressive output and your tv will accept it, this usually works.
Won't work for analog i/o tho'
-K -
are you eventually going to make a feature where you can choose which version to output to? like pal to ntsc or vise versa?
Just made my first svcd with 1.5 and the audio and video are out of sync in the middle of the movie, but appear to be insync in the beginning and end? Not sure what the problem is? Anyone know what might be causing this? I have done different movies with 1.2 and audio and video were insync?
wonderboys. (I am currently trying it as an vcd)
Also can messing with VBR make the final vcd, svcd quality better or only less quality? And what does it mean to leave it off?
thanks
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 10:13
