I have Gainward Geforce 2 MX and i want some instructions as its my first time what cables should i get and how to i go about starting the process and capturing my VHS tapes into my hard drive......
THX
Can you tell us about the capabilities & connectors on your card? There are so many cards that it makes it difficult to know them all. Also what capture softwear came with the card?
I also say this because some cards have video out and some people mistakenly think it is a video input.Panasonic DMR-ES45VS, keep those discs a burnin' -
Well its a CardeXpert Gainward Geforce 2 MX 400 and it has a port called TV out and the next one is a connector for my monitor and that is all that is there.So in fact there are two port one for the monitor and another called TV OUT......I dont know what cables to get and what to do next.
THX -
If those are your only connections, you can't capture with that video card. You need a video capture card with some form of video in connection. Check out:Originally Posted by fdonline
https://www.videohelp.com/forum/viewtopic.php?t=143515
https://www.videohelp.com/forum/viewtopic.php?t=110581&highlight=recommended+card
https://www.videohelp.com/forum/viewtopic.php?t=88466&highlight=recommended+card
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
Capturing VHS files
By Tafflad in forum Capturing and VCRReplies: 4Last Post: 2nd Jan 2010, 21:28 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32 -
Need advice about capturing VHS
By jimlong in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2008, 03:11
