Toast burnt VCDs will only play for about 3 seconds on my stand alone DVD player (they work fine on my iBook). I have read that Missing Media Burner has better results in this area.
I am trying to burn the cue/bin files created by Forty-Two 1.5 (Great program by the way), but I can't seem to find the right driver in MMB. The CD-RW in my iBook is a Sony CRX800E. None of the drivers listed in MMB work for me.
use the generic driver, and DVD-R for the device if it is a combo drive (I know it is not a real DVD-R) - this works on my iBook...
thanks. i'm an idiot. i tried and tried different drivers and nothing worked. then i thought, hey, why not try the dvd-r/rw option. viola! it worked. makes sense too, considering my drive DOES read dvds. i guess i'm just so used to calling it a cd-drive that i forgot it reads dvds as well. dumb, dumb, dumb!
What's a good external DVD burner for my iBook G4?
By KeepItSimple in forum MacReplies: 12Last Post: 12th Sep 2007, 09:08 -
Problem with iBook G3 after ffmpegx usage
By AndyPanda in forum ffmpegX general discussionReplies: 3Last Post: 25th Jun 2007, 16:46
