I have 2 xvid files I am trying to convert to mpg using tmpgnc that have the same problem. It converts fine for the first say 10 minutes but then the picture freezes (but not the program).
Any ideas??
Thanks in advance............
it means that you have bad frames or corrupt data in the video or the audio or both. use divfix to scan for errors or use virtual dub to scan for bad frames and remove them.
Thanks secretagent....
I did find some errors with divfix but can someone please explain how to use Virtual dub to search for bad frames and then how to fix them?
Thanks so much in advance!!! -
Select
Video
Scan video stream for errors.
This will take a little while, but when finished it will record the bad frames. and undecodable frames and mask them. You then save as avi with a new file name, using direct stream copy for both the video and audio. The file will be saved minus the masked frames.
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
AVI (xvid) into TMPGenc plus HELP
By efiste2 in forum Video ConversionReplies: 3Last Post: 4th Dec 2010, 18:30 -
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 15:01 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 23:53
