well im using my FAV program TMPGEnc. (rocks). I have a xvid that is 640 x 352 and 23.976 FPS. I want to encode it to either a svcd or vcd (pal or NTSC). my question is, which format (svcd/vcd and pal/ntsc) would be best to maintain the Aspect Ratio. Also, which aspect ratio setting should i use? 4:3 16:9? 1:1 vga?
any help would be apprechiated
thanks
chad
Test if you're DVD player can handle Xvcd's..... if so you can keep the high res when converting...... I do like this and; very good quality vcd's....
When burning with Nero...... ( if original res is been kept ) ignore warning, just burn it.....to make Xvcd) Try it.
D.C. 8)" Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon. -
Ok.............then these are the basics to work with, but keep in mind that when you want to change 4:3 / 16:9 settings...... some things will change; check the forums for this.
DVD - 720x480, 352x480, 352x240
VCD – 352x240
SVCD 480x480
CVD – 352x480
whenever I make and SVCD I just use the same settings it tmpgenc that are in the avi. For example if its 640x272 then i use that for tmpgenc and i use full screen (not keep aspect ratio). then after i burn with nero and put in my DVD player it plays full screen and reads it as an SVCD.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 03:59
