I'm trying to uninstall the "Darim Vision DVMPEG" codec. I can't uninstall it from Device Manager, but I do have the original *.inf file used to install it. I've already deleted the driver files from the system32 directory, but now I still have to undo everything it did to my system registry. I've never done anything with the system registry before, so I don't want to mess up here. Can someone tell me how to "undo" what the inf file did?
I am especially confused regarding the part in the inf file where it "adds a system ini entry".
[AddSysIniEntry]
system.ini, drivers32,,"vidc.dvma=dvicmau.dll",0
system.ini, drivers32,,"msacm.dvmpega=dvacmau.dll",0
Well, I checked my system.ini file (in the Windows directory), and it only contains a few lines. Is that because WinXP doesn't use the system.ini file? If so, then why is there a system.ini file at all?
Here is the other main part of the ini file, where it modifies registry entries.
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\icm\vidc.dvma,Description,,%*MPEG.DeviceDesc%
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\icm\vidc.dvma,Driver,,dvicmau.dll
HKLM,SOFTWARE\Microsoft\Windows NT\CurrentVersion\drivers.desc,dvicmau.dll,,%*MPEG .DeviceDesc%
HKLM,SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32,vidc.dvma,,dvicmau.dll
HKLM,SOFTWARE\Microsoft\Windows NT\CurrentVersion\Userinstallable.drivers,vidc.dvm a,,dvicmau.dll
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\icm\msacm.dvmpega,Description,,%*MPEGa.DeviceDe sc%
HKLM,SYSTEM\CurrentControlSet\Control\MediaResourc es\icm\msacm.dvmpega,Driver,,dvacmau.dll
HKLM,SOFTWARE\Microsoft\Windows NT\CurrentVersion\drivers.desc,dvacmau.dll,,%*MPEG a.DeviceDesc%
HKLM,SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32,msacm.dvmpega,,dvacmau .dll
HKLM,SOFTWARE\Microsoft\Windows NT\CurrentVersion\Userinstallable.drivers,msacm.dv mpega,,dvacmau.dll
[MPEG.DoReg]
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG1 ActiveX filter...",,"%11%\regsvr32.exe /s %11%\DVMpegB.ax
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG2 ActiveX filter...",,"%11%\regsvr32.exe /s %11%\DVMpegPP.ax
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG3 ActiveX filter...",,"%11%\regsvr32.exe /s %11%\MP2Filt.ax
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG4 ActiveX filter...",,"%11%\regsvr32.exe /s %11%\MpgRec.ax
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG5 filter...",,"%11%\regsvr32.exe /s %11%\mpeg2mux.dll
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG6 filter...",,"%11%\regsvr32.exe /s %11%\Mpegdmx.dll
HKLM,Software\Microsoft\Windows\CurrentVersion\Run Once\Setup,"Registering DVMPEG7 filter...",,"%11%\regsvr32.exe /s %11%\mtrs32.dll
the safest and easiest way to do it is pick a date before you installed the codec and do a
You could try this:
Control Panel - Sound and audio devices - hardware - video codecs - properties
and remove the one you don't want.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Mirror_Image,
That was the first thing I tried. You can access the "Video Codecs Properties" via the Device Manager as well.
The codec appeared to be removed, but then the next time I checked the Properties again, the codec was magically back. And this was before executing any other program.
I don't know how to do System Restore, and since I haven't been doing regular System Backups, I guess it wouldn't do me any good.
A Newbie want to learn the codec pack system.
By beterhans in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2012, 10:36 -
How can I edit cedocida codec settings in windows 7?
By dssdss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Sep 2010, 03:10 -
Is it possible to edit thread titles in this new forum system?
By yoda313 in forum FeedbackReplies: 12Last Post: 5th May 2010, 10:02 -
uninstall every trace of any video codec
By greendesert in forum Software PlayingReplies: 8Last Post: 20th May 2008, 11:27 -
cannot edit wmv videos anymore (need a codec)
By SignedupGuest in forum EditingReplies: 6Last Post: 11th Feb 2008, 11:34
