  1. Hi,
    I want burn a VCD but I found a problem, I have seen that my MPG is 320X240 and not 352X288 like PAL standard. If I try to burn the same, can I find some problem watching it?
    There is a way to change the size of the video file ?
    Thanks in advance, bye!
    Apr 2002
    The State of Frustration
    Most programs will warn you if you try to burn it at that size. If you do get an error, I suggest you go ahead and encode to a proper VCD format before tryin to burn it.
    Hello.
  3. Hi,
    Thanks for yr. reply but my question is different, I mean if the format is not right I can view properly my video on my DVD player or it does not recognize the format??
    Which program do u suggest to "correct" this problem?
    Thanks in advance, regards.
    [/i]
  4. Hi,
    I have seen an article about multiplex with TMGenc to correct file that way trasform my file in a PAL standard MPG?
    Or this multiplex repair only the audio?
    Thanks, regards.
