Im useing movie factory 1 and some of my files go into it but not all.
I convert my files with TMPGEnc plus to a mpeg2 file which I thort was a dvd file but movie factory will not accept it.
What converter should I use and what should I convert 2 so m f 1 will accept it.
Help plz.
Cheers
What makes you think TMPGEnc converted the file to a proper DVD formatted file? Did you use the Wizard, or the template?
Hello. -
Im using the wizard 2 convert 2 dvd pal mpeg-2.
Is that ok 4 movie factory 1 coz i cant seem 2 get it 2 work. -
You may want to try DVDecryptor (freeware) to make sure Movie Factory is not giving you a hard time.
Hello.
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
Trouble with movie factory 6 pro Help!!
By blues100 in forum Capturing and VCRReplies: 3Last Post: 16th Oct 2007, 21:44 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20
