By default - When you put a DVD into your drive to be ripped, DVD Decrypter will select just the movie files-by default.
*NOTE: It will also keep all the menu points. What I mean is that you'll be able to skip from chapter to chapter.
My question is a two part one.
Is there a way with DVD Decrypter that you can choose the MENU of the film that your backing up?
Not just the chapter points - but the little pictures that actually show you what chapter you're going to.
What would the file name be? DVD Decrypter works great backing up just movie files - I'd like to have the movie with menu - that's all.
Thanks for any help...
The menu is just another VTS set.
Basically, if you want the menu, you'll have to rip that VTS too.
You'll have the entire menu. If you leave out any extras only the Scene Selection from the movie would work.
I assume there's no need to tell that it requires some extra authoring.
MrSnakeSony DRU-500A v1.0d
Toshiba SD-M1302 v1006
Philips DVDR885P v1.7/8 -
Thanks! -this worked out for me...
By far the easiest way to back-up my DVDs.
-Leb
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 17:02 -
DVD Decrypter Question
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 28th Jan 2010, 04:56 -
dvd decrypter/dgindex question...
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2009, 09:35 -
question about DVD HD Fab Decrypter/Burning
By Bamahusker in forum DVD RippingReplies: 22Last Post: 19th Nov 2007, 11:33 -
DVD Decrypter Region Question
By nickolasj80 in forum DVD RippingReplies: 2Last Post: 21st Jun 2007, 19:26
