how do you convert rmvb to mpeg
The programs 'TINRA' and 'EOVIDEO' (see the Tools Section) can convert 'RM' and 'RAM' files providing you have Real Media player installed on your system.
I don't have a sample of a 'RMVB' (Real Media Variable Bit) to test if these programs can convert them but try them anyway.
If they don't work, I've heard that the RMVB (Real Media Variable Bit) files may need the latest version of 'Real One' Player installed so try installing this if you don't already have it. -
i want to convert it to mpeg so i can burn on on cd cuz i want to watch it on my dvd player
No problem. Eovideo will convert it directly to MPG (SVCD or VCD format), or you can use either program to convert the RMVB to an 'AVI' file and then use TMPGEnc to make an MPG file (VCD, SVCD or DVD) from the AVI.
I find you get a better quality MPG file if you convert the RM to AVI first and let TMPGEnc do the MPG conversion.
So do this:
1. Convert the RM to AVI using TINRA or EOVIDEO.
2. Make a VCD file (MPG) from the AVI file using TMPGEnc.
3. Burn the MPG CD as a VCD. -
is there a program that converts faster??? i mean tmpgenc converts a lot faster, taht eo video is so slow and how does tinra work i can't seem to get it to work.
Hi there!
I've tried to convert my .RMVB file with eo-video,
but the audio is totally out of sycn!
I tried using VirutalDub to delay the audio already, but it still doesn't help ...
I can sync one part of the movie, but then other parts are out of sync!
I converted it from .RMVB -> VCD MPEG1.
Any suggestions?!
Help!
-Kor -
okie dokie peoples...
i have found away 2 do this... fist of all get rid of your real players...
this is what you need:
(1) real player alternative
(2) codecs (these 2 you get from the kazaa lite web site and that is http://www.kazaalite.tk/
(3) rawaverecoder
(4) TMPGEnc
All you do is extract the audio using (3) then open (4) and well you know the rest... and there you go...
It works i was at my wits end till i tried this and now i'm happy... please if this works for you to please post this on other websites so everyone else can benifit from it...
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:09 -
ffmpegX to convert rmvb
By Ninacita in forum ffmpegX general discussionReplies: 7Last Post: 31st Jan 2009, 23:14 -
How to convert AVI to .RMVB?
By whatever911 in forum Video ConversionReplies: 15Last Post: 29th Nov 2008, 11:29 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
A New Way To Convert RMVB to AVI
By RMVBMASTAPRO in forum Video ConversionReplies: 2Last Post: 27th May 2007, 18:41
