I have been trying to make a copy of The Holy Grail w/o success. No method syncs properly and I've tried many over a period of a week.
Here's something I discovered tonight. There are 5 VOB's on the DVD. All of them are needed for the movie (I looked at each one with VLC). If you add up the total size of these VOB's it comes to 4.71 GB. However when I use 0SEX to exctract the elementary streams, the total size of them are video=3.81GB and audio 126.5MB.
I am very new to this and this may be a stupid question but could this be the reason for the syncing problem (i.e. that the sizes don't match the original)?
I am going to run one more test. I will extract as a program stream and see if the resulting VOB matches. more later...
OK using the Program Stream method, it produced a VOB 3.99GB. I don't understand...
Are you extracting ALL the audio? Usually OSEx will do the movie vobs, and nothing else...unless you tell it to do the dvd folders or dvd image selection. Otherwise it does the movie and the audio for the movie. If you're deselecting other audio like french or dolby 2.0 (leaving only the 5 or 6 channel ac3... then of course the resulting files are going to be smaller.
Wiqd -
Of course .. You're right. I feel very foolish. Thanks for the help.Are you extracting ALL the audio? Usually OSEx will do the movie vobs, and nothing else...unless you tell it to do the dvd folders or dvd image selection. Otherwise it does the movie and the audio for the movie. If you're deselecting other audio like french or dolby 2.0 (leaving only the 5 or 6 channel ac3... then of course the resulting files are going to be smaller.
Oh well, I still have the sync problem.
Add audio don't work on ffmpegX
By petwes in forum ffmpegX general discussionReplies: 1Last Post: 28th Jan 2012, 04:51 -
A couple of things that don't seem to be working here....
By Noahtuck in forum FeedbackReplies: 9Last Post: 16th Jul 2010, 01:56 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
How to add a VCR when I don't have any more inputs except Serial & 15P
By Alucard41 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2008, 15:40 -
I have a .ass but I don't know how to add it to a video...?
By darkzero297 in forum SubtitleReplies: 1Last Post: 23rd May 2007, 21:24
