  1. What program can i use to watch my tv on computer full screen? In my capture progs if i change res to higher than 740x480 it doesnt show the tv. is there anyway to take the picture from 352x240 and strethc it to the whole montior? please reply asap, i need this working within 20 min... thanks
    Australia
    You should have recieved a TV viewer program with your capture card, capture programs are not general purpose viewers so you won't be able to make them full-screen.
    If you don't have the software bundled with the card I suggest you get onto the manufacturer's web site, they possibly have a compatible TV viewer for download.
    Alternatively, if you indicate your card type here, then perhaps someone can point you to the appropriate software for the card.
    Hi
    I am also interested in watching TV on my PC as I would like to use it to play some of my old games on my N64. I believe my card has tv tuner functionality built into it.
    My card is a Pixelview MX440 SE VIVO. I have installed the Nvidia WDM drivers and it added all sorts of devices like a/v crossbar etc.
    Unfortunately I need some software to be able to do this. Any ideas?
    -Darren
    canada
    I found InterVideo WinDVR to be the best program for watching capture in full screen
  5. You can preview full screen with Amcap (freeware).
    http://noeld.com/dlvconf.htm
