  1. I have 2 files: bbMPEG_Muxed_File00 & bbMPEG_Muxed_File01 that I tried to create a SVCD using NERO but I used 48000Hz,2 channels audio by mistake. How do I extract the AUDIO/VIDEO and reassemble them using 44.1 audio instead allowing me to create a SVCD ?? thanks in advance....
    MO, US
    Use tmpgenc's MPEG Tools to demux each file to the m2v (video stream) and mp2 (audio stream). Use tmpgenc, besweet, or whatever audio tools you prefer to convert the mp2 files to new mp2 files at 44.1kHz. Use bbmpeg to multiplex each new mp2 file with the matching m2v file (you could also use tmpgenc to multiplex, but bbmpeg does a better job).
    If you use tmpgenc to convert the audio be sure to configure ssrc as the external sample rate converter, tmpgenc's built-in converter isn't very good. You can find quite a bit of information on that by searching the forums.
  3. When I goto load the M2V file into TMPGE it says that file is UNSUPPORTED...??
  4. TMPGenc might need the MPEG2 plugin available in the Tools section. Make sure its priority is near the top.
    Panasonic DMR-ES45VS, keep those discs a burnin'
